Community
cancel
Showing results for
Search instead for
Did you mean:
KDuff
How do I correct Error 8714 message when deploying Firmware Update 9.1.41.3024?
I need to apply Intel Firmware Update 9.1.41.3024 using SCCM to our workstations but I'm getting an error - "Error 8714: Firmware update not initiated due to file open or read failure". I am using the 'FWUPDATE.BAT' file provided with the update.  I tried to run the .bat file on the system with the same results.
n_scott_pearson
Super User Retired Employee
Sorry, this forum is dedicated to the support of Intel's Desktop Board products. There's no one here that can readily answer questions related to Workstation or Server products. You need to re-post your question in the Server forum (I don't have the ability to move it for you).
