Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
How to disable touchpad on dell model G5 5587 window 10 home (64 bit)
TouchpadG55587Dell
Dear All,
I faced a difficulty to disable my touchpad on Dell G5 5587 , window 10 home (64 bit). I have research on internet source about the methods, for example disable in touchpad setting, driver etc. However, in my  specific case, I couldn't look for this driver or setting in my PC in control panel - touchpad setting. Could you kindly advice please ?
Thanks and best regards,
Alex
AlHill
Contact Dell for support and/or the touchpad driver.
Zee_Ahmed
There are several ways to disable, the most effective is to Device Manager.  Right-click on This PC and click Manage.
And uninstall it. You might see the disable option on your laptop.
It might be the permanent solution as upon restarting; the driver will be installed again.
Another great solution is to install the latest touchpad software driver from the official website and disable it.
Let me know if it works.
Zee Ahmed,
Founder at One Smart Sheep
(Moderator removed link)
