Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
How to fix stuttering in multi monitor setup?!
FGia
On Windows 8.1 x64 latest drivers 3/3/15 dual monitor with an amd r9 290 and intel HD 4600. Enabling the second screen causes stuttering, videos and other stuff aggravates the stuttering! If I disable the hd 4600 display adapter from device manager, stuttering is gone, how to fix it? Is it even possible?
Jose_H_Intel1
Did you try changing the refresh rate or using previous driver version(s)?
FGia
Already tried refresh rate changes but does not help at all. I fixed the stuttering tough, it was caused by some polling done by an app called f.lux, there is a safe mode in it that disables constant polling and stuttering is gone.
Framerate reduction is still present tough, a lot more evident when playing videos. It happens when the stuff is played on the second monitor, the one attached to the onboard vga, and the framerate on the firstmonitor drops. I have read around that this problem should happen when 2 monitors are attached to the same card and not on different cards.
What I also noticed is that if I play videos from MPC using MADVR as renderer it causes framedrops, but if I use system default renderer there is no framedrop, playing videos from browser causes framedrops but a browser causes framedrops in general because it uses GPU not only for videos.
I don't know which older driver versions should I try.
