Community
cancel
Showing results for
Search instead for
Did you mean:
GGG00
How to overclock dp43bf main board
DP43BF motherboard+CPU-X3360+8G memory+RTX2060
I want to use this motherboard to overclock CPU, how to set in BIOS. Motherboard bios-0088
AlHill
Are you serious?
Also, your processor is not supported on that board:
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DP43BF
Doc
n_scott_pearson
Super User Retired Employee
Actually, I think the tables are wrong in this case. The board's TPS says X3000 series Xeon processors, as well as Core 2 Duo and Core 2 Quad processors, are supported, but the tables don't list any of these as supported (and should). Regardless, this hardware is so old that, even with overclocking, a modern Atom processor is likely going to kick its a$$. As far as this endeavor is concerned, I don't do or believe in overclocking so I cannot provide any insights into how to use the BIOS parameters for this and I do not believe that XTU supports processors this old.
GGG00
Hello there I found the overclocking option in the motherboard BIOS, but I can only overclock slightly. Through inquiry, I found that someone overclocked this CPU to 3.5GHZ for normal use. But I can only overclock to 2.9GHZ. Although this CPU is very old, it is not used by me, it is for children. Its performance is sufficient for children.
n_scott_pearson
How much you can overclock is going to vary from one processor to another. Regardless, this system is 9+ years old and on its last legs. If it is really going to to be used by children, why are you jeopardizing its continued existence trying to overclock it?
GGG00
I already use it, but I can only overclock it a bit.
GGG00
Squeezing its extreme performance, it is still possible to play some games with it.
