Are you serious?
Also, your processor is not supported on that board:
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DP43BF
Doc
Actually, I think the tables are wrong in this case. The board's TPS says X3000 series Xeon processors, as well as Core 2 Duo and Core 2 Quad processors, are supported, but the tables don't list any of these as supported (and should). Regardless, this hardware is so old that, even with overclocking, a modern Atom processor is likely going to kick its a$$. As far as this endeavor is concerned, I don't do or believe in overclocking so I cannot provide any insights into how to use the BIOS parameters for this and I do not believe that XTU supports processors this old.
How much you can overclock is going to vary from one processor to another. Regardless, this system is 9+ years old and on its last legs. If it is really going to to be used by children, why are you jeopardizing its continued existence trying to overclock it?
Squeezing its extreme performance, it is still possible to play some games with it.
