Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
How to recover and reset BIOS in Intel DB85FL Desktop Board ?
SAnan3
Hi, I'm using Intel DB85FL Desktop Board. I have changed video settings in BIOS menu, after restart my PC it didn't display anything and not even enter into BIOS. To recovery my BIOS, I have tried many methods like recover bios using .bio file and Jumper reset but nothing works. It just give 2 beep sounds and in screen No signal message. Kindly help me in this.
Kevin_M_Intel
Hello sri241290,
Please try clearing the CMOS. Here you have the instruction: http://www3.intel.com/cd/channel/reseller/emea/eng/membership/411560.htm http://www3.intel.com/cd/channel/reseller/emea/eng/membership/411560.htm
This should do the trick.
Kevin M
AHuss12
Dear kevin_intel,
What if there is the same issue after doing the mentioned Process (i e removing the CMOS and putting it back after an hour).
Kevin_M_Intel
Hello azhar429,
In that case, if the issue persists after, you should give us a call at our technical support center: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
