Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to set RAM frequency to 1600 MHz for DH77EB motherboard with i5-3550 processor?
I bought a computer installed with an i5-3550 processor on the DH77EB motherboard. It has 8 GB (4 GB x 2) Kingston HyperX RAM. The default memory frequency is 1333 MHz and I have to manually change it to 1600 MHz to fully utilize the RAM chips.
When I try to change the speed, I get the following options:
8:1067
10:1333
12:1600
Along with the options mentioned above, the following parameters also show up.
tCL = 9
tRCD = 9
tRP = 9
tRASmin = 24
The thing is that I don't know whether I should keep the last 4 parameters (9-9-9-24) as is. Also I don't know what the '12' in 12:1600 means. Please help.
Thanks!
Community Manager
Re: How to set RAM frequency to 1600 MHz for DH77EB motherboard with i5-3550 processor?
Hello Akash,
The memory controller built-in on the processor will support DDR3-1333/1600 rated at 1.5V. Our recommendation is contacting the memory manufacturer directly to confirm which profiles the memory you have installed will support:
http://ark.intel.com/products/65516/Intel-Core-i5-3550-Processor-6M-Cache-up-to-3_70-GHz ARK | Intel&# 174; Core™ i5-3550 Processor (6M Cache, up to 3.70 GHz)
Highlighted
Thanks Dan! I switched to the 12:1600 option without changing anything else and its working fine.
