Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
How to set RAM frequency to 1600 MHz for DH77EB motherboard with i5-3550 processor?
APras8
I bought a computer installed with an i5-3550 processor on the DH77EB motherboard. It has 8 GB (4 GB x 2) Kingston HyperX RAM. The default memory frequency is 1333 MHz and I have to manually change it to 1600 MHz to fully utilize the RAM chips.
When I try to change the speed, I get the following options:
8:1067
10:1333
12:1600
Along with the options mentioned above, the following parameters also show up.
tCL = 9
tRCD = 9
tRP = 9
tRASmin = 24
The thing is that I don't know whether I should keep the last 4 parameters (9-9-9-24) as is. Also I don't know what the '12' in 12:1600 means. Please help.
Thanks!
Community Manager
Hello Akash,
The memory controller built-in on the processor will support DDR3-1333/1600 rated at 1.5V. Our recommendation is contacting the memory manufacturer directly to confirm which profiles the memory you have installed will support:
http://ark.intel.com/products/65516/Intel-Core-i5-3550-Processor-6M-Cache-up-to-3_70-GHz ARK | Intel&# 174; Core™ i5-3550 Processor (6M Cache, up to 3.70 GHz)
APras8
Thanks Dan! I switched to the 12:1600 option without changing anything else and its working fine.
