You can try, but I doubt it will work:
Look at section 1.1.1 on page 9 of the tech spec:
Doc
Well, read the spec. It says no.
Doc
In the spec they said 2gb memory technolgy but the board support up to 16 gb it contain 4 slots how can u insert 16 gb in 4 slots using 2gb memory ? i did not clear in the specs
To get 16gb, use 4 * 4gb modules. Each module used 2GB technology.
Just purchase two 4gb modules, you will be in spec. And, memory is cheap.
Doc
It refers to the density of the memory, typically meaning chips on both sides of the module.
Do not get hung up on this, or insisting on using one 8gb module. Just use 2 4GB modules and you will be fine (and in spec).
Doc
The board can only support 1Gb and 2Gb memory technology (this is the technology of the chips used on the DIMMs). This means that the maximum supported DIMM size is 4GB. 4 x 4GB = 16GB total. That's it. If you don't like this limit, don't purchase this board.
You mean 8GB? It requires 4Gb or 8Gb technology chips. b = bit. B = byte.
this board support i7 7th gen processors
Not a chance. It only supports 1st gen Core processors.
That is a 1st gen processor.
I am no longer following this thread.
Doc
Please read the following documents. This is what is supported as far as memory and processors.
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DH55TC
If you want to play with something else, then that is certainly your prerogative . Just do not complain when it does not work or you cannot return it or you damage your board,.
Doc
