Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
I am sorry because I am not sure how to post or where to post. It has to do with an incompatible driver in my Toshiba Laptop. It has to do with core isolation, memory integrity. I get this message attached when I tried to turn it on.
OKASS1
The message has to do with incompatible files. The one that is incompatible is idgkmd64.sys. I downloaded the Intel updater but it did not find anything to update.
AlHill
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
OKASS1
Could not find the paperclip so copied file here.  Hope this is OK.
AlHill
Sorry, run the utility as I asked, and then follow the instructions under the reply box, namely "Drag and drop here or browse files to attach "
Doc
