Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
I can't access BIOS on DH67BL: keyboard unresponsive?
AVier
I'm trying to access BIOS on DH67BL, using a Microsoft Natural Ergonomic Keyboard 4000 in a USB 2 port. Hitting F2 for Setup does nothing, neither do F7 or F10 (which are supposed to be BIOS Setup, BIOS update and Boot Menu, respectively). I'm sure I have been able to access BIOS before on this motherboard; but I'm not sure if I have been able to access it with this keyboard. I have no other keyboard for testing. Once the operating system loads the keyboard is fully functional again.
I have tried setting the jumper for BIOS maintenance mode: that opens up the maintenance mode, but there's no keyboard functionality there either so I can't make any changes or even view the settings. I also have tried removing and replacing the battery to restore default settings in case I have inadvertently previously changed something in BIOS: the clock was reset, but apart from that no difference (well, the computer didn't boot up properly then - fans turned but no signal to the screen - after that. Until I reset the jumper for BIOS maintenance mode and then back to normal, and now it boots up tnormally, but no difference where I was trying to make one.)
I'm thinking it could be an issue with the keyboard, but I can't test that now. What else could it be? How to fix or get around this? For now, I just want to set my new SSD as the first boot option, but in the end I really should be able to access BIOS anyway.
ppara5
Valued Contributor I
Make sure your keyboard and mouse are plugged into one of the USB 2.0 motherboard ports, not in an add-on card.
ppara5
AVier
Thank you! Moving the mouse too to a USB port on the motherboard seems to have made the difference as I can now access BIOS.
