Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
I have a DH67CL desktop board and the specs for ram say Four 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets • Support for DDR3 1333 MHz and DDR3 1066 MHz DIMMs • Support for 1 Gb, 2 Gb, and 4 Gb memory technology
CMull13
 Support for up to 32 GB of
System memory with 4 DIMMS using 4GB memory technology.
Question is how can I get 32GB memory when says only 4 X $ Gb ram memory ?
LeonWaksman
32GB is the total memory supported by your board. That means you can use for example 4 SODIMM modules, each of 8GB capacity. 4Gb (rather than 4GB) technology, means that each SO DIMM contains 16 DRAM devices (each 4Gb and 16 x 4Gb = 8GB).
Leon
