Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
I have a Gateway PC with a motherboard DG33SXG2 i just want to know if i can put more RAM
LGonz9
Now i got 3 Gb from factory and i want to put at least 2 of 2 gb more, it´s possible? because i put the number in the search for the ram and it came up nothing and i only want toknow the specification so i can buy more ram to have at least 6 Gb, i hope you can help me with this doubt, thank you!
AlHill
You will need to check with Gateway, as I do not believe this is an intel board. However, it may have been manufactured by Intel specifically for gateway. Whatever the case, you will need to contact Gateway.
Also, if your OS is 32-bit, going over 4gb of memory will be of little value.
Doc
n_scott_pearson
Super User Retired Employee
The 3GB number that you have is actually what is available to Windows to use. In fact, your system has 4GB of physical memory (it just can't use it all because of BIOS (etc.) requirements). The G33 chipset is capable of supporting up to 8GB of memory. Whether this motherboard will support 8GB or not is something that you will have to aks and have Gateway answer. I know that Intel's boxed G33-based motherboard products can support 8GB...
...Scott
P.S. Doc is correct; if your board can take 8GB and you successfully upgrade it, you will have to install a 64-bit O/S in order to utilize the additional 4GB of memory.
LGonz9
I think is an Intel board, but if I understand correctly to the other comment, I can put 8gb of memory but it will be no difference because I have to install a new version of Windows, like Windows 7? Am I correct? or i will feel the difference between 3gbs that i have now and the 6 or 8 that i will put in the board, Thank you for the reply
AlHill
You may be able to go to 8gb, or maybe not. You will need to confirm with Gateway.
Windows 7? What OS and architecture do you have currently? Windows XP, Windows Vista? 32 bit or 64 bit? As said before, to use more than 4gb of memory, you will need a 64-bit OS.
As far as the board being Intel, as I said before it may have been made by Intel for Gateway. In this case, Gateway needs to provide the relevant information.
Also, this is an old board. Spending time with questions and trying to configure this board may cost you more than purchasing a current board.
Doc
