Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
I have a Intel DH61SA board and performed a bios update to ver 0048 and then tried to update it to 0099. The update was successful but the system kept on booting into the bios. After following instructions to remove jumper and replace jumper the system ke
SFish7
I have a Intel DH61SA board and performed a bios update to ver 0048 and then tried to update it to 0099. The update was successful but the system kept on booting into the bios. After following instructions to remove jumper and replace jumper the system kept booting in the bios, after that it booted up to a screen that was filled with Intel writing all over the screen, booted down and that was the end of it. System no longer boots up to any screen, no logo, bios, bootup keys nothing. I tried the various recovery options but non seems to work. Please advise accordingly if there is a fix or if i should start looking at another board? Thank you
Anonymous
Not applicable
Hi Bash_Man,
Try to upgrade again the BIOS with the version 99 using the recovery option, remove BIOS jumper, use 1 memory stick only.
Mike C
