Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
I have a problem with my DX58S02
SHerr5
Good morning, I have a problem with my DX58S02, black screen, not beeps, 1. fan go on, 2. tested the PSU is ok. 3. did disconnect the AC power when I took it apart. I stripped the system down to bare case, with only the PSU, HDD, and the disc drive still installed. After I re-assembled everything, and connected all the pins and cables, including the 4-pin on the mother board. I connected AC power and tried to boot the system, but there was no beep and no video, even though the fans are turning, and still don't working.?
2 weeks working without luck.
n_scott_pearson
Super User Retired Employee
The chassis itself can possibly be a significant contributor to problems; in future, you should remove the board from the chassis for isolation tests. It's a pain I realize, but...
Have you gone through the troubleshooting processes suggested here: http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm? Specifically, have you tried resetting the BIOS configuration?
The SO2 board has a 2-character hexadecimal post code display on it. What are you seeing happen on this display when you power on?
...Scott
SHerr5
Only give 00 immediately.
Thank you for your answer I appreciated a lot.
n_scott_pearson
Hhmmm, I am racking my brain here. I know I have seen this issue before but it's been so long that I don't remember the possible cause(s) .
You said that you tested the PSU. How? Did you try substituting another PSU and see if the operation stayed the same? If not, try this - and take the board out of the chassis when you do so. If this was being caused by a ground loop, for example - which could occur if the PSU is starting to fail but hasn't completely - taking the board out of the chassis and testing on a grounded surface could yield a difference...
