Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
I need a bios update for DH55TC
JMani5
I need a bios update for DH55TC with windows 10 os cannot find one or even one later then 2011.
n_scott_pearson
Super User Retired Employee
Latest available BIOS release is attached. Do you need instructions on how to install? [Hint: BIOS Recovery is the best process if big gap between your current and this latest BIOS.]
Gusan
I downloaded the file but I can't install it, how do I run the .bio file?
And another question, I have the BIOS TCIBX10H.86A.0048.2011.1206.1342,
dated 12/6/2011, put an 8Gb memory with the appropriate specifications for the motherboard but it does not work. Should I update the BIOS? or what is the problem?
n_scott_pearson
For information on the BIOS Update process, consult Intel Desktop Boards BIOS Update Instructions and, for this case, Intel Desktop Boards Recovery BIOS Update Instructions.
To help you better, here are my step-by-step instructions for performing the BIOS Recovery:
  1. NOTE: Read these instructions completely before starting. Follow all instructions EXACTLY.
  2. On some other Windows-based PC, make sure that you have the .BIO file for the BIOS release you wish to install.
  3. Insert a 32GB or smaller USB 2.0 flash drive into the PC. Do not use USB 3.0 flash drives.
  4. On a Windows-based PC (NOT Linux- or MACos-based), reformat this USB flash drive using the Windows Format applet. Select to install the FAT32 file system (NOT vFAT, NOT exFAT; FAT32 only). You must also specify that the Quick Format option be Disabled (unchecked).
  5. NOTE: If FAT32 is not offered as a choice by the Format applet, your USB flash drive is too big; use another.
  6. Copy the .BIO file into the root folder of this USB flash drive. This should be the only .BIO file in the root folder of this USB flash drive.
  7. Properly eject the USB flash drive. Do not just yank it out. Do this from File Explorer or using the Safely Remove Hardware and Eject Media System Tray applet.
  8. Power off the Desktop Board system.
  9. Remove the yellow BIOS Configuration jumper from the board. It will be the only yellow jumper on the board; the rest will usually be black.
  10. NOTE: Remember the pins that this jumper was plugged onto; you will need this information later.
  11. Plug the USB flash drive into one of the black USB 2.0 ports on the back panel of the board. Do not use blue or yellow USB 3.0 port. Do not use any front panel USB ports.
  12. Power on the system.
  13. The BIOS Recovery process should start automatically. You should see a progress report on your main monitor.
  14. NOTE: If you do not see a progress report displayed on a monitor, do not power off the system for at least 15 minutes! While it is rare, it is possible for the process to proceed without an onscreen display; you must give it ample time to complete, just in case. Powering off at the wrong point in a BIOS Recovery operation *will* brick the board.
  15. When the BIOS Recovery process is complete, you will be asked to power off the system. Do so.
  16. Restore the yellow BIOS Configuration jumper to the pins it was on previously. This should be across pins 1 and 2 of this (3-pin) header.
  17. Remove the USB flash drive from the back panel of the board.
  18. Power on the board.
  19. Immediately begin pressing the F2 key, over and over (approx. once per second) until you see the BIOS Setup (or Visual BIOS) screen displayed.
  20. Verify, using the BIOS version string, that the BIOS installed properly. Stop if it isn't.
  21. Press the F9 key (followed by the Y key) to reset of the BIOS configuration.
  22. Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
  23. Once screen is cleared (goes black), begin pressing the F2 key, over and over, until you see the BIOS Setup screen displayed.
  24. Make any changes to the BIOS configuration that you desire (for example, disabling NUMLOCK) or that you require (for example, setting Boot Order, enabling UEFI, etc.).
  25. Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
  26. Test.
Hope this helps,
Gusan
Tengo el BIOS TCIBX10H.86A.0048.2011.1206.1342, con fecha 12/6/2011, puse una memoria de 8 Gb con las especificaciones apropiadas para la placa base, pero no funciona. ¿Debo actualizar el BIOS? o cual es el problema
n_scott_pearson
You are following (exactly!) the process I identified above? If not, you should retry it this way.
