Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
I've DG41WV, it gets restart every after awhile itself
Community Manager
I'm having restart problem I tried to figure out but I couldn't
It gets restart every after awhile and I've no fucking idea what to do with this, Hard Drive is fine coz i was using this before with other system, RAM or MotherBoard could be the reason and it has only problem with Windows 7
Community Manager
Hello Farooq,
These are our recommendations to narrow the issue:
- Test the system with minimum memory installed, swap memory modules and test them individually.
- Check the BIOS version for your board; make sure you have the latest version for your board:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21330&ProdId=3246&lang=eng&OSVersion=... Download Center
-Instructions can be found here:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
- If the issue persists, you can try formatting the hard drive and re-installing the Operating System using the latest driver from our website:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=... Download Center
Community Manager
Hello Farooq,
