Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
I want to get back Visual Bios
ecast7
i updated BIOS of Desktop Board DB85FL. to the last version i lost it after i had to format my pc, the main reason of doing that was because i wanted to handle my pc fans and temperature from bios, now i can see the options below the intel sign, F2 to access setup just show me a black screen and the other option is F7 that one is update bios, i discovered that the version that comes with the fan controller is called Visual Bios, so i got the last Visual Bios i run the installation and is showing me the error: downgrade version is not allowed, and i cant continue, when i purchased my PC it came with Visual Bios so i know it works in my PC, i tried updating trough flash drive and other solutions that are mentioned but none of them work and are not specific to the problem that im having. I would really apreciate if you can show me a solution for this problem. Thanks
Kevin_M_Intel
Hello jestebanc,
I am sorry for your trouble but let me help you.
All 8 Series Intel® motherboards come by default with the Visual BIOS and every single update will make internal changes but always keeping the visual BIOS.
I recommend you doing a BIOS recovery process. Here are the steps:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
Kevin m
