Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
INTEL Desktop Control Center WIN7 pro
GRein3
IDCC 5.5.1.84 will not run on WIN7 Pro. It was running fine on basic home but since i upgraded it will not run I get a port error. Anyone know of this or how to fix it?
Silvia_L_Intel1
RobyneHeud, please let me know which is the model number of your motherboard and the current BIOS version?
This download is valid for the product(s) listed below. https://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=18023 Download Center https://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=18023
Intel® Desktop Board DP55KG
Intel® Desktop Board DP55SB
Intel® Desktop Board DX58SO
BIOS Requirements
Make sure you have the appropriate BIOS installed as follows:
- If Intel® Desktop Board DX58SO, use the BIOS: SOX5810J.86A version 5559 or newer
- If Intel® Desktop Boards DP55KG or DP55SB, use the BIOS: KGIBX10J.86A version 5924 or newer
If you're not sure what BIOS version is installed, restart the computer and press F2 to enter the BIOS setup. The BIOS version will be displayed.
For example, BIOS SOX5810 is noted as follows: SOX5810J.86A.5559.2011.xxxx.xxxx.
