Hi, I have DH77EB mother in which am experiencing a typical problem last few days..
After system is awakened from a long sleep, the network is not connecting and shows up a error 'Intel 82579V Gigabit network connection is experiencing a hardware or Driver related problem' but when i restart, the network gets connected and works fine.. I even tried installing latest drivers but still am experiencing the same problem... Any permanent solution to this???
Hello Fazil,
Have you also tried uninstalling the driver from device manager?
You may reset the TCP/IP stack: Open cmd as admin and run the commands below, then restart.
Netsh int ip reset
Netsh winsock reset
Perhaps updating/flashing the BIOS may also help.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20dh77eb Download Center
In case the issue persists after a clean installation of the operating system you may need to contact your local Intel support team.
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Hi Fazil,
We are having the same problem, did the suggested solution work for you? Every morning we are having to reboot to get connected.
please help me i recently updated my pc to windows 8.1 pro 32 bit and i have intel DH61ww mother board when i turn on my pc after a long sleep i cant connect to the internet it shows the error that " intel(R)LM 82579 gigabit " network connection adapter is experiencing driver or hardware related problems
but when i open manage from my pc and in device manager manually select network adapters there it shows
" intel(r) 82579V gigabit" network connection adapter when i check for updates it shows it s already updated
this network connection problem will be fixed when just restart the system but if i shutdown my pc and turn it on after 1 or 2 hours the same problem will appear again in order to get internet access i needed to restart the pc in every time
lineesh, you can try the following driver even though Windows* 8.1 is not officially supported for the motherboard model you are using.
I suggest you uninstalling the older driver before installing this one.
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23071 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23071
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported Operating Systems
