Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel Bios Engineers (DZ77BH-55K)
Hey guys, how do we contact the guys who make the bios/fixes? When I Call tech support they walk me through a bunch of troubleshooting steps, which honestly are a waste of time because I know these issues are bios related.
1)Flashing Power LED when computer is on, happened after Bios 0083
2) USB 3.0 front panel wont work, PIN 10 needs to be disconnected. (perhaps can't be fixed in bios, but atleast supply an adapter with pin 10 disconnected)
3) My Wireless USB keyboard\mouse combo doesn't let me enter the bios (Microsoft Wireless Desktop 3000)
all threee issues aren't user related, all are something Intel should fix, yet when I call Intel they spend 20 minutes making me try a bunch of stuff to get it to work.
Highlighted
It was posted elsewhere in this forum that disconnecting pin 10 would enable the front panel USB3, but I didn't know if that was officially acknowledged or confirmed by Intel. Yeah, if it's a real bug in the board, I'd expect Intel should be handing out adapters.
Highlighted
Community Manager
I hope they do something soon, having no front panel USB 3.0 is a major issue!
Highlighted
I had the USB problem and still have the Wireless desktop problem.
If you disconnect pin 10 the problem goes away. I didn't want to cut the pin on the mobo so I bought a 20 pin male to female adaptor (on ebay, search for USB 3.0 Box Header 20-Pin Male to Female Adapter Extender on ebay) and with a very fine pointed plyers bent pin ( in the adaptor) 10 backwards and forwards until it broke off right at the base of the connector. Pin 10 is diagonally opposite the missing pin i.e. its a 20 pin connector with only 19 pins. I put the adaptor (with pin 10 removed) between the mobo header and the front panel header connector and the problem was fixed.
I believe that Intel has now update the mobo to fix the usb 3.0 issue.
For some reason (the bios) the wireless desktop transmitter drops power when Windows is not running. The Wireless keyboard issue I have not been able to resolve, everytime I need to go into bios I disconnect the wireless desktop and connect a wired mouse and keyboard. You may also find that you can come out of sleep with the wireless desktop because when the pc goes into sleep the power drops off from wireless transmitter plugged into the usb port, another bios issue.
Highlighted
Community Manager
I got the Front USB to work after I enabled 3rd party USB. Seems kinda stupid that the front panel USB is controlled by 3rd party USB. My mobo had pin 10 missing already, so I got lucky.
Highlighted
Yes, the front panel USB 3.0 requires the Renesas driver the rear panel uses the Intel USB 3.0 driver.
The USB 3.0 (20 pin plug) only has 19 pins, do you have 2 pins missing, pin 10 & 20?
Could you also let me know what board revision you have, use the Intel ID tool (on line version) available here http://www.intel.com/support/motherboards/desktop/sb/CS-012681.htm Desktop Boards — Identify your board using the Intel� Board ID Tool
My board is version: AAG390008-400, I believe the -600 version has been modified to elimate the USB 3.0 issue.
Have you made any progress with the wireless desktop issue?
Highlighted
Community Manager
HI 845GLM NO DISPLAY PLS HELP ME
Highlighted
I've got the front panel problem, and my board is -400.
If Intel had shipped a buggy rev, I'd expect a tech post somewhere warning and advising. Is there any such doc? Seems that the problem is real, but everything I'm seeing is from customers and is anecdotal and theoretical. What does Intel have to say?
Highlighted
I am not aware of anyone from Intel admitting there is an issue. Follow this link http://qdms.intel.com/dm/d.aspx/630E74D6-7A63-42B3-892B-AACA6BDCF04E/PCN111511-01.pdf http://qdms.intel.com/dm/d.aspx/630E74D6-7A63-42B3-892B-AACA6BDCF04E/PCN111511-01.pdf and you will find Intel Product Change Notification 111511-01 it relates to board a modification that says "It is to prevent false over current error on the Front Panel USB 3.0 header." After reading the document the modified board is not out until November, it was originally due in July, I think.
I think this says there is a problem and possibly a warranty claim for those with boards that does what mine does, brings up an over current error message and non-functioning front panel USB 3.0 ports. Unless Intel come up with a better explanation, that's what I assume. Another thought is that people with cases that have don't have USB 3.0 front panel connectors wont know there is a problem until they upgrade the case, they may never know. If Intel come out and admit a problem it could start a flood of warranty returns, a costly exercise for Intel.
In the mean time to fix the problem buy a "USB 3.0 Box Header 20-Pin Male to Female Adapter Extender" on ebay, they are only about $8.
With needle nose pliers bend (very carefully not to bend the adjacent pins) pin 10 (shown in the next picture) backwards and forwards at its base until it breaks off. Install the adaptor between the header and front panel plug.
I did this and the error message has gone away and the front panel usb 3.0 connectors work.
Highlighted
Community Manager
I think only 1 pin is missing, however I haven't had a single issue with the front panel once I enabled 3rd party USB in the Bios.
I can't use that intel tool, I run Mac OSX on my board.
Highlighted
I did what you (Michael Smith) suggested and it worked! The USB3 front panel sockets are now functional.
For the record, my case is an Antec Solo II. I purchased the connector on eBay, as suggested. I was skeptical, but figured the experiment was safe enough, and the cost was only $7.49. (I wouldn't have risked intentionally breaking a pin off the motherboard!) Here's the current eBay listing:
http://www.ebay.com/itm/280762364930?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 http://www.ebay.com/itm/280762364930?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
So this would seem to be a bug in Intel's hardware, and we might reasonably expect Intel would be offering modified adapters to correct it. I don't mind paying the $7.49 to get the thing working, but it's not good that I've got to get this tip from another user instead of an official word from Intel, and breaking off the single pin requires some tools and dexterity.
Highlighted
Valued Contributor I
Hi
A new version of the BIOS has been posted, seems okay so far, fixes the flashing power light, it's now steady, even though this isn't a fix listed in the release notes.
Has options for secure boot now in the BIOS for UEFI users.
Phil
Highlighted
Hi
The fix for the flashing power light may be part of the WHCK issues (Windows Hardware Certification). Itel could have elaborated on the statement in the release notes "Fixed issues related to WHCK". so we know what they fixed. I hope my wake issues are included as well as the wireless desktop not being recognised in post issue are included.
I will update my bios when I have time and let you know.
Michael
Highlighted
I flashed my BIOS to version 0091 and it would not go past post after it was done. I tried it twice and had to recover back to version 0083 both times.
The Board Status LEDs were:
A, Hard Drive Activity = off
B, CPU Hot = off
C, VR Hot = off
D, Watch Dog Fire / Back to BIOS = off
E, CPU Initilization = on solid
F, Memory Initilization = on solid
G, Video Initilization = on solid
H, USB Initilization = on solid
I, Hard Drive Initilization = off
J, Option ROM Initilization = off
K, Operating System Start = off
Port 80 POST sequence display reads "92" which is "Detecting the Presence of a keyboard".
I have a OCR Vertex 3 SSD, I suspect that the BIOS update caused issues detecting the SSD. Any suggestions welcome.
I am going to put this out as a post
Michael
Highlighted
Hi
I updated by using the .BIO file on a USB stick in a USB 2 socket, no issues here, using an Intel SSD.
My steps are:
  1. Reboot machine and start hitting F2 to enter the BIOS.
  2. Do a reset to defaults (before attempting to update)
  3. Save and Exit then as it reboots hit F7 to enter BIOS update screen
  4. Select the USB drive and the BIO file and update the BIOS.
  5. When it reboots after the update is complete, immediately hit F2 to get into the BIOS screen, another reset to defaults and reboot
  6. Straight back into the BIOS and make the necessary setting changes I want
Also make sure options for UEFI secure boot or try UEFI boot first are disabled. By default the new BIOS seems to want to attempt a UEFI boot, and if that doesn't work it tries legacy. I'm not sure how reliable it is trying one and falling back to another.
Maybe that might help.
Phil
Highlighted
Community Manager
go into classic bios mode
enable UEFI and Legacy Boot.
if you disable legacy boot it get's stuck at 92 no keyboard, atleast with bios 0085 for me it did.
Highlighted
Community Manager
With the new BIOS my power LED still flashes.
I tried pulling the power for 2 mins, and when I booted up again, it stopped flashing, however after a restart it started to flash again
Highlighted
Hi
How odd, I've re-started my machine several times and the power light flashes for a couple of seconds while it starts then is steady.
Did you do a reset to defaults after updating?
Phil
Highlighted
My power LED only flashes to indicate the PC is in "Sleep" mode, here's a long shot but may be worth a try. Could a setting in "Power Options" be set to sleep within a very short time. Go into Power Options, if it's not already, set it to "Balanced" and then set the scheme to defaults, it may help.
I assume you enabled UEFI and Legacy Boot before you updated the BIOS and the settings were retained when the BIOS is updated.
I have a feeling I may have to update the firmware on my SSD as the status LEDs indicate the SSD is not initilizing - this is apparently an issue with the early firmware with OCZ, SSDs.
Michael
Highlighted
Community Manager
I restored defaults right after flashing the update, also I run Mac OSX on my computer, however it did this with windows before.
