Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Intel Corporation DQ35JO (J1PR)
iice
i have motherboard Intel Corporation DQ35JO (J1PR) it this support 2 monitor ?
i don't have graphics card.
but the graphics integrated in the motherboard support 2 monitor?
i ask this beacuse i want 2 monitor and i dont know if i need to buy Graphics Card and Cable Matters VGA Monitor Y Splitter 1 Foot
or only : Cable Matters VGA Monitor Y Splitter 1 Foot
like this in amazon:
http://www.amazon.com/Cable-Matters-Monitor-Splitter-Foot/dp/B005H3I38G/ref=pd_sim_pc_10 Amazon.com : Cable Matters VGA Monitor Y Splitter 1 Foot : Electronics
Piriform Speccy:
graphics:
monitor
Name SyncMaster on Intel Q35 Express Chipset Family
Current Resolution 1280x1024 pixels
Work Resolution 1280x984 pixels
State Enabled, Primary, Output devices support
Monitor Width 1280
Monitor Height 1024
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer Intel
Model Q35 Express Chipset Family
Device ID 8086-29B2
Revision 3
Subvendor Intel (8086)
Current Performance Level Level 0
Driver version 8.15.10.1930
Count of performance levels : 1
Level 1
Manufacturer Intel
Device ID 8086-29B3
Revision 3
Level 1
motherboard
Manufacturer Intel Corporation
Model DQ35JO (J1PR)
Chipset Vendor Intel
Chipset Model Q35
Chipset Revision A2
Southbridge Vendor Intel
Southbridge Model 82801IO (ICH9DO)
Southbridge Revision 02
BIOS
Brand Intel Corp.
Version JOQ3510J.86A.0669.2007.0821.2354
Date 21/08/2007
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Bus Width Unknown
Slot Designation PCIE X16 SLOT
Slot Number 0
Silvia_L_Intel1
Ido, this specific motherboard supports dual display, which means that you can connect 2 monitors to the board without using a video card. The board comes with a DVI-D connector and a VGA connector.
http://ark.intel.com/products/50382/Intel-Desktop-Board-DQ35JO?q=35jo http://ark.intel.com/products/50382/Intel-Desktop-Board-DQ35JO?q=35jo
It is also important to have in mind that Intel guarantees the functionality of our graphics controllers and video ports when using straight connections from the motherboard to the display device (monitor, TV, projector, etc) and we don't recommend using adapters or converters.
I will appreciate if you can provide me the model number of the processor just to verify if the CPU supports dual display also.
I was able to see that you are not running the latest BIOS, however if the system is working fine, you can keep using the same version. If not, here is the list of BIOS versions available and the specific fixes and features add to the board.
http://downloadmirror.intel.com/19638/eng/JO_1143_ReleaseNotes2.pdf http://downloadmirror.intel.com/19638/eng/JO_1143_ReleaseNotes2.pdf
Regards.
iice
only way to me to know the answer is to try?
there is no other way that i can get this info ?
Silvia_L_Intel1
Regards.
iice
Silvia_L_Intel1
iice
i think i did bad choose that i I bought Cable 1 pc to 2 VGA SVGA Monitor like this in amazon[ http://www.amazon.com/Gino-White-Monitor-Splitter-Cable/dp/B007PODLCI/ref=sr_1_10?s=pc&ie=UTF8&qid=1... Amazon.com : Gino White 1 PC to 2 VGA SVGA Monitor Y Splitter Cable Lead 15 Pin : Computers & Accessories ]
i should bought USB TO VGA like this in amazon[http://www.amazon.com/StarTech-com-Multi-Monitor-External-Adapter/dp/B002FJQXXC/ref=sr_1_1?s=pc&ie=U... Amazon.com: StarTech.com USB to VGA Multi Monitor External Video Card Adapter - 1440x900 - USB to VGA External Graphics Card: Electronicshttp://www.amazon.com/StarTech-com-Multi-Monitor-External-Adapter/dp/B002FJQXXC/ref=sr_1_1?s=pc&ie=U... Amazon.com: StarTech.com USB to VGA Multi Monitor External Video Card Adapter - 1440x900 - USB to VGA External Graphics Card: Electronics]
now it detect me only 1 Monitor in the windows 7,
is any software that can help me in this situation ?
maybe missing driver is the problem ?
Silvia_L_Intel1
Ido, once again Intel guarantees the functionality of our graphics controllers and video ports when using straight connections from the motherboard to the monitor, TV, projector, etc. Any kinds of adapters, converters or cables are not recommended.
  • Please provide me the model number of the processor you are using?
You can also try updating the BIOS, since the current BIOS version is 0669 and there are 23 newer versions available.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DQ35jo... https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DQ35jo...
The following link will show you the method you can follow to update the BIOS. http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm
You might want to update the BIOS to these versions: 0696, 0757, 0865, 0942, 0991, 1109, 1143.
I recommend you to install all these versions before updating to the latest one, since there are plenty updates available.
iice
on my motherboard i have only 1 VGA adapter
if i buy vga that contact to dvi and then connect to the motherboard dvi ?
like this:
[http://www.amazon.com/Syba-Connectland-CL-ADA31002-Female-Adapter/dp/B002R0DZXU/ref=pd_sim_e_3&tag=s... http://www.amazon.com/Syba-Connectland-CL-ADA31002-Female-Adapter/dp/B002R0DZXU/ref=pd_sim_e_3&tag=s...]
i will have 2 screen?
i want 2 different screen
i try update my bios but it Doesn't work it give my bug report will give you this later,
i actually i will try 3 screen i I bought this StarTech USB to VGA External Video Card Multi Monitor Adapter - 1920x1200
so if i can make 2 screen that connect to the motherboard is be nice.
2 different screen that i can dialog with,
