Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Intel D2500CC Motherboard and 2x2G memory
Community Manager
I have brand-new D2500CC motherboard and two SO-DIMMs 2GB each.
It is Hynix 1Rx8 PC3-10600S-9-11-B2 HMT325S6CFR8C-H9 two-sided 8 chips modules.
When I try to install both modules, motherboard doesn't boot and beep with memory error signal.
Each module, installed alone, works well.
What is my problem? Whic memory should I buy instead (what should I check) to have 2x2GB configuration?x2GB
Community Manager
Hello Lev,
The memory modules that you are utilizing should work properly on your system, or at least I cannot find a reason why it does not.
In regards to your inquire, we have some tested memory modules that you can find at the following web site:
http://www.intel.com/support/motherboards/desktop/d2500cc/sb/CS-032630.htm http://www.intel.com/support/motherboards/desktop/d2500cc/sb/CS-032630.htm
Regards.
Community Manager
Hello Lev,
Regards.
