Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Intel D425KT Desktop Board Onboard Audio Device Not Working
CPriy
Hi Team,
I have installed Windows 7 Ultimate in my desktop. Its having a D425KT motherboard. Onboard audio is enabled in bios. Still its not being detected by the OS. I have installed the below driver files. Also I have tried using the Intel Driver Update Utility Installer. Still no luck.
  1. INF_allOS_9.2.0.1030
  2. LAN_allWin7_7.017_PV_RTL
  3. GFX_Win7_32_15.12.75.50.7.2230_PV_Intel
  4. AUD_allOS_11.50.0.43969_PV
below is the output of the board id tool.
Below is the device manager screen.
Appreciate your help on resolving this.
Jose_H_Intel1
Are you using Windows* 7 32-bit or 64-bit? Only Windows* 7 32-bit is supported.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported Operating Systems
Do you have a front panel audio connected to the header (see page 13)? Do you get sound in the back panel if you disconnect the front panel?
http://downloadmirror.intel.com/19122/eng/D425KT_D425KTW_TechProdSpec03.pdf http://downloadmirror.intel.com/19122/eng/D425KT_D425KTW_TechProdSpec03.pdf
