I was able to get into the bios settings of an Intel D845WN briefly after not using it for a year. I have a POST code reporting card and the last code before it stops is 30, and the second last is 2D. All the keyboard does is flash all the lights when the computer is reset. I thought I needed to reprogram the bios so I did that with the recovery mode and a floppy disk but it has made no difference. On the screen there is a flashing cursor at the top left corner. I have tried different video cards and memory. There is nothing else attached. I think it has developed a fault soon after been switched on and it would have to be replaced.
Hello Fraser,
Please bear in mind that this product has reached its End of Interactive Support since 2004 so Intel no longer provides interactive support for this product via telephone, chat or e-mail.
http://www.intel.com/support/motherboards/desktop/sb/cs-016974.htm http://www.intel.com/support/motherboards/desktop/sb/cs-016974.htm
You may want to try basic troubleshooting:
- Test the system out of the chassis, minimal configuration please. (Motherboard, processor, power supply, 1 memory stick and video card)
- Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
-Install the latest BIOS version available for your board https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d845wn%22&DownloadType=BIOS https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d845wn%22&DownloadType=BIOS
-If the motherboard is still under warranty please get in touch with our Warranty Department and ask for additional information since the replacement option for this product is not available anymore. http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Regards.
Hello Fraser,
Regards.
