I have and older gaming system and the mother board finally went. I was looking for the latest compatible mobo with Intel D875PBZ mother board. thank you for your help
Hello MM123:
In regard to your question, I just wanted to let you know that the Intel® D875PBZ board was released back in 2003 so the documentation currently available is not that much, let me apologize for that and the reason for that is because is retired, discontinue and our of support.
Additionally, there is not an specific model that is compatible or that follows that specific model, in this case the best thing to do will be to check the specifications of the board and then try to find one that have those same specifications, on the following link you will find the technical product specification for that board, where you will be able to check all the details about it:
https://downloadmirror.intel.com/15199/eng/D875PBZ_TechProdSpec.pdf https://downloadmirror.intel.com/15199/eng/D875PBZ_TechProdSpec.pdf
Also, remember that Intel does not manufacturer anymore, so as an option you can always look a motherboard from a different manufacturer like ASUS, ASrock, or MSI.
Alberto
Michael,
What you actually should be looking for is a board that is compatible with your processor. Focus your search based upon your processor...
Ok, that said, the problem here is that this processor is not really worth building a replacement system around. A modern Atom processor will have far better performance (and cost a whole lot less). My recommendation is that you replace the system in its entirety.
Hope this helps,
Hello:
Thank you very much to N. Scott Pearson for the suggestion posted previously.
To MM123 :
Hope that information was useful for you.
Any further questions or if you need further information about this matter, please let me know.
Alberto
