Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Intel D945GCNL
Community Manager
My Desktop Board is Intel D945 GCNL. I installed 2GB RAM and 512MB Video Card. Recently i installed 2 more GB of RAM and now in the system properties, it shows only 2.49GB instead of 4GB. Please help me in this.
System Configuration Details:
Mother Board: Intel D945GCNL
Processor: Intel Core 2 Duo E4600 @ 2.40 GHz
RAM: 2 x 2 GB DDR2 @ 667MHz
OS: Microsoft Windows XP Professional X64
Community Manager
Hi Princechennai,
Unfortunately this motherboard supports on a maximum of 2GB of total memory. Hence i guess this is the main reason why you are not getting the full 4GB that you have on the system, even if you are using windows xp 64 bit version.
More information for memory on this board: http://support.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026728.htm
Cheers.
Community Manager
Hi, I want to know whats the maximum Memory capacity for each Slot ? as there are two slots only can i plugin a 2GB RAM for a single slot ? and also will there be any harm to the Motherboard or the RAM if i plugin a 2GB and a 1GB RAMs for both slots seperately, as Princechennai has stated that he has 2.4GB RAM as the total. So at least I can get some additional 0.5GB ? Is this a good method ?
TIA.
Community Manager
Since the maximum capacity of memory supported on this board is 2GB, hence the maximum memory supported on each slot is 1GB. For best performance it is recommended to use equal memory capacity on each slot since you will then have the memory working in dual channel, thus 2 x 1GB is the best configurations for this motherboard.
• Dual channel (Interleaved) mode.
This mode offers the highest throughput for real world applications. Dual channel mode is enabled when the installed memory capacities of both DIMM channels are equal. Technology and device width can vary from one channel to the other but the installed memory capacity for each channel must be equal. If different speed DIMMs are used between channels, the slowest memory timing will be used.
• Single channel (Asymmetric) mode.
This mode is equivalent to single channel bandwidth operation for real world applications. This mode is used when only a single DIMM is installed or the memory capacities are unequal. Technology and device width can vary from one channel to the other. If different speed DIMMs are used between channels, the slowest memory timing will be used.
Sometimes, some 2GB modules may work in one slot only, but that does not mean it is supported. As far as I know, i will not do any harm to your system if you use unsupported memory on the system. (It will either work or not). But however, changing memory configurations and timings in BIOS may make the motherboard unusable.
Hope this will be helpful.
Cheers.
Community Manager
IS THE ORIGINAL OF THE BOARD BIOS D945GCNL
I need help because the unconfigure and I want to recognize the Intel Pentium Dual Core 1.8 GHz
Community Manager
Hi all - I didn't have any problem in having 4GB DDR2 667 MHz being installed in my system with D945GCNL board.
My system is running on Vista Ultimate . Before Service Pack 1 it showed 3.25 GB of RAM and then after Service Pack 1 it showed 4 GB of RAM.
My System Config
Processor : Intel C2D E4500 @ 2.2 Ghz
Motherboard : Intel D945GCNL
RAM : 2 * 2 GB @ 667 MHz
Graphics Card : Nvidia 7300GT
Hard Drive : 2 * 500 GB Seagate SATA
Sound Card : Creative Sound Blaster
PSU : 500 W
Optical Drive : 2 * Sony DVD Drives
OS : Windows 32 - bit Vista Ultimate
http://img64.imageshack.us/img64/1765/19422114.jpg
Community Manager
Thx for sharing and posting your info on ram, francisxavier.p
I just picked up this mobo w/ 2GB ram from a friend a while back. Just now getting round to setting it up w/ a dual boot XP/Win7. Put in the same HD as you have...but after getting the op systems set up I wanted to upgrade the ram. mine may or may not work as yours did but at least you certainly gave me hope....as a matter of fact based on your experience w/ this same chip set Intel D945GCNL that we have....I have made the observation (as I am certain you did as well!)....just to consider specs from manufactures as a good source and guide but NOT absolute truth on ALL things....you are proof of that w/ your 'against-the-odds' install and working fine of 4 GB ram! If you don't mind, what brand of ram are you currently using in this system?
Thx again for your post.
Paul
Community Manager
Today I replaced my (2 x 1 GB 667 MHz) DDR2 with (2 x 2 GB 800 MHz) DDR2 ram modules on Intel D945GCNL motherboard (with latest BIOS update = NL94510J.86A ver. 0036)
& the RESULTS are:
Bios: Shows 4096 MB of ram running at 667 MHz. (that's the max. ram FSB supported by motherboard)
OS: (Win 7 SP1 64bit) Shows ram = 4.00 GB (3.24 GB usable)
Task Manager: In performance tab under physical memory shows Total memory = 3317 MB.
Hence, i have no idea what francisxavier.p is talking about as (in any case) the real usable memory still remains about 3.24 GB.
As proof see the following snapshots:
http://img854.imageshack.us/img854/8484/12323384.jpg http://img854.imageshack.us/img854/8484/12323384.jpg
http://img24.imageshack.us/img24/4282/68519204.jpg http://img24.imageshack.us/img24/4282/68519204.jpg
My advice is to upgrade upto 3 GB ram max. that's it instead of ruining your money on 4 GB ram.
If francisxavier.p has motherboard with BIOS NL94510J.86i ver. 0005 (iPAT support) then may be his PC is running on 4 GB usable memory but I cant confirm that.
Regards.
RAM: 2 x 2 GB DDR2 @ 800MHz (Running @ 667MHz)
OS: Microsoft Windows 7 Ultimate SP1 64bit
Community Manager
Hey Sarmad06,
Thx for your most recent post.
You gave me sum-thang to think about....my Bios.....it probably needs updating as well.....gotta go read and find out
how to do it....never done that before - glad you mentioned it.
I posted earlier in a response to another poster about the ram. Currently running 2GB ram but changing it out to the
4GB (same as you installed on your board). Also running a low-end processor but changing it out today to a duo-core,
http://www.geeks.com/details.asp?InvtId=PD945-R Intel Pentium D 945 3.4GHz 800MHz after it arrives. Diff is you are running 64 bit and I have a duo-boot XP and
Win7 home 32bit on this board Intel D945gcnl. ....hopefully, the ram is gonna take....that is one of my concerns.
But too, this system is set up w/ a radiator/waterjacket-coolant over the processor. I am not liking how the heat levels are.
I have made some adjustments on it but still running a little too warm for my preferences.
That's one of the reasons I am changing out the chip and of course to get a higher-end duo-core in there as well.
After I get this stuff 'dialed-in' I will post the results for all to view.
Thx again for making/taking the time you did to share your results....appreciate that.
Paul
Community Manager
Hi sarmad06,
I believe you could help me through with my confussion. I have a system configuration with the following specs:
Motherboard : intel D945gcnl
Processor : Pentium D 2.79Ghz
RAM : 1x2GB
OS : 32 bit windows XP SP2
I'm looking for a graphic card which would be compatible with my motherboard and supoprt MAYA 2012,
I have two graphic cards shortlested which comes within my budget and i'm not sure if they are compatibnle with my pc.
'XFX Radeon 6790" and "NVIDIA GeForce GTX 550 Ti "
Could you please advise me of any such graphic card. i've been looking for one for about three months now and couldn't come up with the one right decission.
Thanks and regards,
Deepak Vimal
Community Manager
I have D945GCNL Mother Board. 1gb DDR2 667MHz RAM, 2.2 GHz C2D Processor.
I want to Upgrade my RAM to 3GB but Intel says the Maximum total System Memory is 2GB[http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026728.htm http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026728.htm].
I am using 64 bit Windows-7. If I upgrade it to 3GB does all 3GB RAM will work or 1GB will be wasted. Or it will be wasted if I use 32 bit OS.
Please Help.
Community Manager
hii intel,
i am ambrish jawalkar and i have question to ask is ... I HAVE INTEL D945GCNL MOTHER BOARD WITH 1.6GHz DUAL CORE PROCESSOR AND 2GB DDR2 RAM AND I NEED 3GHz PROCESSOR .. SO IS IT POSSIBLE TO HAVE 3GHz PROCESSOR FOR THIS MOTHER BOARD ? IF YES PLZ REPLAY ME AT ****** personal information edited ******
PAUL PLZ HELP ME....
Community Manager
intel D945GCNL Pentium 4 with two processors 3.0 & 3.0
some body tell me can i install 4 GB ram i have already installed 2 GB & 512MB ram
is my board support 4 GB RAM
Community Manager
Can anyone please tell me does Intel 945GCNL support XFX Radeon hd4870 1gb (ddr5) graphics card?????
I'm really looking for this...
My PC configuration is:
Community Manager
Shouldn't be a problem. Your motherboard has a PCI Express 1.1 slot which works with PCI Express 2.0 graphics cards like the one you mentioned.
Community Manager
Thank u so much Brad for your response....
Michael2020
October 2020, found an old and dusty D945GCNL motherboard with a Pentium E2160 sitting in a box. Cranked it, worked. Added 2 GB RAM, then 3, then 4. Works without a hitch in Windows 10 Pro, with 3.64 GB usable memory reported. Apparently there was in fact a later revision that enabled the board to use 4 gigs of memory. Gonna upgrade the processor to a slightly faster Core 2 Duo 2.2 GHz that's also sitting around tomorrow. I'll report back.
kamelot28
Hello good morning, I have the same Intel D945GCNL E7500 4RAM board, despite that, I thought I could install Windows 10 pro 64bits. I can only install everything in 32bits. Install BIOS NL94510J.86I.0005
kamelot28
the bios NL94510J.86I.0005. being installed no longer allows me to install the BIOS NL94510J.86A0036. because it will be, and a corrupt BIOS message appears. There is a way to put the 0036
n_scott_pearson
Super User Retired Employee
Your installed BIOS identifier starts with NL94510J.86I? That is a vendor-specific version of the board and, in this case, this means that you cannot use the Intel-generic NL94510J.86A BIOSs. You will have to contact the vendor in order to get any BIOS updates.
Sorry,
