Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Intel D945GTP Desktop Board
JThom22
Good day Everyone, I have an Intel D945GTP desktop motherboard that I just received. Even though it is second hand it is fairly brand new. The problem I am experiencing is that, when I boot up the computer, the board does not respond. The fan on the heatsink that is attached to my CPU does not even spin. However, I do notice a small LED that is lit green, and it stays on for the whole time. I tried swapping the power supply with a new one, and it still does the same thing.But, what I notice on the motherboard is that there are 2 capacitors that are bulging and are about to leak. Could it be that these components are the source of the problem or is it something else ?. I don't want to get rid of this motherboard because I feel it can serve a greater purpose in the near future. What should I do ?. FIY the 2 bulging capacitors can be found next to the DIMM sockets on your right.
AlHill
VERY OLD board, with bulging caps. The best advice I can give you is to toss it into the trash bin. This board has long since reached its usefulness.
http://downloadmirror.intel.com/15171/eng/D945GTP_SpecUpdate08.pdf http://downloadmirror.intel.com/15171/eng/D945GTP_SpecUpdate08.pdf
Save yourself a lot of time and money, and get a board that is still supported. And, it is likely that your memory and processor will accompany the board to the trash bin, as they will not be usable on a newer board..
Doc
P.S. Not that this is a cause of the problem, but when was the last time that heatsink was cleaned?
Community Manager
Hello, All:
If your motherboard has bulging caps, I am afraid that there is nothing you can do, and as mentioned before by Al_Hill the best advice in this case is to get a newer motherboard.
Amy.
