What you have asked is a bit ambiguous. Here are answers to both interpretations of the question:
- The on-board graphics subsystem has both VGA and DVI-D outputs. It is possible to utilize a DVI to HDMI adapter/cable (US$10 example at http://www.amazon.com/C2G-Cables-Go-42516-Digital/dp/B00CQSYS48/ref=sr_1_5?ie=UTF8&qid=1454635752&sr... Amazon.com) and thus connect to a HDMI TV (for example). Understand that this HDMI signal will not include audio, however. If you want a full HDMI with audio, you will need a more sophisticated (and more expensive!) DVI+Audio to HDMI converter (US$70 example at http://www.amazon.com/StarTech-DVI2HDMIA-Video-Converter-Audio/dp/B005G3VQ5E/ref=sr_1_5?ie=UTF8&qid=... Amazon.com). Similarly, there are also VGA+Audio to HDMI adapters (US$20 example at http://www.amazon.com/Converter-Support-Laptop-Desktop-SD-ADA31040/dp/B00KVJFMG2/ref=sr_1_6?ie=UTF8&... Amazon.com) that you could use - and which are a lot cheaper!
- The board has a PCIe x16 slot and can support an add-in graphics card. Many of these have an HDMI output. Be careful going this route; many of the latest graphics card will not work in a board this old.
Hope this helps,
...Scott
