Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel DG45ID MotherBoard - Endless Start Loop
Today I was configuring the BIOS settings on my motherboard and changed my memory setting from 667 to 800Mhz manual. Now the computer starts for about 1 second and loops without entering BIOS post. I have tried to reset the BIOS but no luck. If I remove the memory I get 3 beeps but when I install the memory back onto the motherboard the same loops starts again. I have 800Mhz CL5 memory. What advice can you give me?
Thank you,
Joe
Community Manager
I have the exact same problem. Tried everything to no avail. I guess the only way is to RMA this device to Intel.
Highlighted
Community Manager
I have read somewhere that if you use CL6 or higher and a true 800mhz memory this will solve the problem. But I haven't found any to try it out. Any help from the Intel??? Please???
Highlighted
Honored Contributor I
If you can get back in the BIOS check and make sure the RAM volts is still at 1.8 volts ??
