I am not able to find a compatible for intel DH55TC motherboard. Please help
DDR3-1333 RAM is not plentiful anymore. I have had 100% success with Corsair XMS3 on 6-series boards. It should be okay for DH55TC. Newegg has it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251&ignorebbr=1 CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model TW3X4G1333C9A G - Newegg.com
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145315&ignorebbr=1 CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model CMX8GX3M2A1333C9 - Newegg.com
Hello, All:
Thank you paramountain for the links provided to find compatible RAM on this Motherboard.
sahilahmad Those sticks are compatible with the memory accepted in the Motherboard: DDR3 1066/1333
If you require any further information or support, feel free to contact the Intel Communities again.
Esteban C
thank you all. RAM suggested by you is not available in india. Anyway I have ordered ADATA XPG DDR3 4 GB PC (Ax3u1600w4g9-Rb). Its a dual channel RAM, It is on the way and I hope it shall work on my Intel DH55TC.
Thank you once again
Hello, sahilahmad:
Good to know, I look forward to your outcome with this new RAM to be tested.
Esteban C
In the mean time I would to share results of 2 RAMs tested on this board.
1. Corsair DDR3 4 GB(1 x 4GB) PC RAM (CMV4GX3M1A1600C11) and 2. Transcend 4GB DDR3 1333 MHz (TS512MLK64V3N) Works good on 32 bit Operating system and boot-loop on 64 bit O.S.
Both the RAMs doesn't work on 64 bit OS and even new setup not working.
Hello, sahilahmad:
The best configuration to be used with this motherboard would be: DDR3 1333 MHz and DDR3 1066 MHz SDRAM DIMMs
Any RAM module that exceeds those specs, we cannot assure they would work properly with your system.
The motherboard and CPU are designed to handle those specs and exceeding those specs would result in forcing the MCH (memory controller hub) inside the CPU, which would lead to incorrect behaviors from the whole system.
The issue could be the DIMM slots as well.
Esteban C
Hello, sahilahmad:
This is to follow up on this inquiry you posted in our communities.
If you require further information or support, please do advise us.
Esteban C
Hi There, i'm really hoping you can help me too.
I've been wanting to upgrade my ram to 4GBx2 or 4GBx4... but i cant find any ram in South Africa that is compatible to the DH55TC motherboard, im really hoping someone can help me with this.
Look forward to some feed back.
