Intel DH55TC motherboard, will it support 2 TB internal Hard disk?
pretty sure it can for any hdd size, the only difference i see with "sata revisions" is transfer rate, so i imagine like usb would be backwards compatible. since that board has 6 sata ports if one is being used for internal dvd you still have 5 left to use for hdds!
now the real question is if your case has room for 5 HDDs!
Yes, of course it can support this size. I have used 2TB disks with all of the 5 series boards.
Are you asking ahead of trying this or did you already try and had a problem?
Thanks Scott and Blackmoore for the information; sujit1779, did the information provided helps you?
Hellen.
Hi sujit1779,
Thought I would just check in and find out if you were able to resolve this problem, and if the information provided helps you.
Hellen.
