Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Intel DH55TC stuck on boot loop after Firewire PCIe card installed
JDe_L5
Hello!
I have a problem with my desktop computer on DH55TC motherboard. I've just bought a Firewire PCIe card and can't boot now.
When I push the power button, the fan starts spinning and after about 5 seconds everything turns off. After a few seconds the system starts again and turn off so it's stuck on a loop. No video signal while this happens and sometimes there are 2 beeps looping (no video signal). Sometimes it displays the Intel logo startup screen but can't continue with boot process or get into the BIOS with F2 key. If I unmount the Firewire PCIe card, everything works OK.
My setup is like this:
Intel Core i5-750 2.66 processor
RAM 8 GB (1x4GB, 2x2GB).
ATI Radeon HD 4650 1 GB (PCIe x16 port)
Momentus XT 500GB Hybrid HDD
DVD-RW Drive
Hyper Tx3 Processor Cooler
600W Power Source
I've already updated the BIOS (TCIBX10H.86A), tried to boot without HDD and separate RAM modules with no results.
PCIe card model is Manhattan 160353.
Any hints to solve it?
Thank you.
Kevin_M_Intel
JuanJ,
Let me help you with this problem you have.
All the information you have provided is very helpful and complete but there are some other steps I want you to try. The BIOS version you posted does not reflect the exact version so I would like you to do the BIOS update using the F7 method.
Here you have the instructions:
http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm
Also it is important to mention that there may be a compatibility issue with the card. Have you tested other cards? When you connect a different PCI card besides the dedicated video card what happens?
Kevin_M_Intel
JuanJ,
JDe_L5
Kevin,
The update I applied was version 4800 (Latest, release date: 12/06/2011) with the express method (Windows Installer).
I don't have another PCIe cards to check the port, I've only used the PCI (not PCIe) before with no problems.
I'll try the update it with the F7 method and I'll tell you how it works.
Thanks a lot for your help.
JDe_L5
Thank you very much, Kevin.
Looks like express update method did not work well. Tried it with the F7 key method and my PCIe card is now recognized
Boot went very slow after update but I've read over the Internet it was the network boot option, I disabled it and everything is fine now.
Thanks again!
Kevin_M_Intel
Nice! I am happy to hear it is good to hear is working.
