hello everyone
I bought DH61WW used from my friend
Installed Intel G620 Processor
On turning PC on, I got no display but pc fans started, I pressed restart button and on boot it started giving display
I pressed F2 and went into bios
And bios were very different from my old DH61WW which I sold In october last year, this one has mouse support
(Will update bios version of my old mobo, I have contacted buyer, waiting for reply). and interesting thing bios show different motherboard at Top : DH61BE bios version 0099 25/5/2012
i went into system identification on main page of bios and it showed DH61ww
I turned off PC, turned on and no display, tried this several time to make sure its first boot no display issue
then I asked him, he tried installing latest bios on his Office DH61ww and got same issue, his pc showing DH61CR and no display on first boot,
I thought of installing latest bios, but on searching google I found many issues on 0099 bios, and dead mobo on flashing other bios
So should I update latest bios? will they work good or wait for fixed bios?
Hello Muhammad,
Our recommendation is proceeding with a BIOS recovery update to the latest version 0113.Please be sure to read and follow all accompanying instructions, which can be found at this link:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
The latest BIOS update can be found here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3325&DwnldID=22516&ProductFamily=Deskt... Download Center
Hello Muhammad,
thanks for your reply,
can u be more specific with term Recovery update?
I mean I should not update through normal methods, and choose recovery method?
Same problem happened with me when i upgraded to bios 0099 but I hv successfully recovered my PC.
You cannot down grade your bios , so update it to latest version (0113) using the recovery method as define in this site http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm?wapkw=desktop+f7+method Desktop Boards — Instructions for F7 BIOS Flash update, after this the boot screen flashes and it appears again and again. To solve this problem you have to install OS again.
Kindly mark it as correct answer if it helps
