Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
Intel DH67BL 3 beeps in all condition.
MLate
Hi, I Have 2 Brand New Intel Motherboard DH67BL and a problem.
I Put a Intel Pentium G2120 and 2 bank of Kingston KVR1333DS8N9H 2GB on one of this motherboard, plug the 450W Power Supply and make all connection for the USB front panel and button.
When i try to power on i hear 3 long beeps repeating. I know it's a memory problem and i try to remove a bank, move the ram in all 4 slot, change the ram with a 1066MHz, add a video Card but nothing work.
I Changed motherboard and i tried all i wrote before and i had the same result: Nothing work.
I tested the RAM and the Video Card in a other machine and seems to work fine.
The only thing i can't check is the proc.
I double check the pins on processor socket and the processor and seems to be ok.
Am I unlucky? I made some mistake? please help me.
Thanks.m,
Silvia_L_Intel1
Hello LaMax,
I would like to let you know that this motherboard and processor combination may be compatible. http://processormatch.intel.com/compdb/SearchResult.aspx?ProcNbr=G2120&BoardName=DH67BL%20&Lang=en-U... http://processormatch.intel.com/compdb/SearchResult.aspx?ProcNbr=G2120&BoardName=DH67BL%20&Lang=en-U...
Please provide me the AA# and serial number of your motherboards and the Spec number of your processor.
Regards.
MLate
Hi, this is the data from my motherboard:
AA G10189-209 and serial number is BTBL13600BUU
Here's the Spec number of the processor: SR0UF and product code BX80637G2120
How I can check the bios version? I Have to buy an other Processor? Thanks
Silvia_L_Intel1
LaMax,
The original BIOS version on this motherboard with AA# G10189-209 is the 0119. According to the compatibility list I provided you and in order to use the Intel Pentium G2120 processor, you would need to update the BIOS to version 0150 using a fully compatible processor.
The best option for you at this point is exchange the processor for a fully compatible one http://processormatch.intel.com/compdb/SearchResult.aspx?BoardName=DH67BL&Lang=en-US http://processormatch.intel.com/compdb/SearchResult.aspx?BoardName=DH67BL&Lang=en-US or get a fully compatible motherboad to your G2120 processor http://processormatch.intel.com/compdb/SearchResult.aspx?ProcNbr=G2120&Lang=en-US http://processormatch.intel.com/compdb/SearchResult.aspx?ProcNbr=G2120&Lang=en-US
Regards.
