Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel DH67BL BIOS Update to 0132->Boot Problem
Guys..
Just updated my BIOS to firmware 0132.
The update was successful.
But Im not able to boot to my Win xp or Win 7.
After selectig the OS.
I get BSOD 0x0000007B (0x80786A58, 0xC0000034, 0x0000000, 0x0000000
Any solutions.
Just upgraded my PC two days back and updated the BIOS today morning..
My Config:
Intel i3-2100-3 Ghz
Intel DH67BL motherboard
Corsair 4GB Ram 1333 Mhz
Seagate 500GB SATA
ATI Radeon HD4650 1GB DDR2
Community Manager
You might be facing a completely different issue here,
but here are my two cents:
A BIOS update normally resets all BIOS options to default values.
If, for instance, you are using a RAID configuration, and update the
BIOS, the RAID setting will be changed back to some non RAID
setting, and you will get a BSOD on every boot.
Additionally, you can get a BSOD, if your original setting was AHCI,
and the BIOS default setting is non AHCI (or whatever it is called).
Therefore, you could try to skim through some BIOS settings,
especially boot device related ones, and reset them to their
original values.
And, if you are at it, just to be on the safe side, reset all BIOS
values before making these changes.
Hope this helps.
Community Manager
Yeah.. it was indeed the problem of AHCI.
I just changed AHCI to IDE.
Now windows xp and windows 7 boots without any problem.
Community Manager
Anyone knows if, after update for bios with ivy bridge support, the MOBO loses the support for sandy bridge?
