Community
cancel
Showing results for
Search instead for
Did you mean:
RKoch1
Intel DH77EB Display Port
Jump to solution
Hello
Does anybody know if the DP of the DH77EB Mainboard needs paasive or active Display Port cable? I have a DP to HDMI cable and want to connect to my TV so i need a DP++ Port. I cannot find any informations in the manual.
I only find this: DisplayPort output can also be converted to HDMI using a DisplayPort-HDMI converter.
Keks22
AP16
Valued Contributor III
You need active cable/converter in case of:
- DP-VGA transition
- need for over HD resolutions/over 60 Hz refresh rates/over 32-bit color depth image transfer to DVI or HDMI
- more than 2,5 meters cable lengths (no matter to what standard converted)
To connect close HD-TV to PC passive converter should be enough.
AP16
- DP-VGA transition
