Hello everybody! I bought a motherboard Intel DN2800MT and IPS flat-panel CLAA070WP03 XG. Wired according to datasheet. BIOS set up. I get the picture from the matrix at 1280 * 800 with the rotation of 90 degrees. In the BIOS settings, there is support for this resolution, but the picture is similar to the resolution of 800 * 1280 instead of 1280 * 800. In the settings you select the resolution for LVDS have items with the inscription "Reserved". How to add the resolution 800x1280?
This panel it has no EDID information on board. Therefore I choose WXGA (1280 * 800)
Thanks for the pictures. Based on the information, since the panel does not EDID information, seems that is not reading 1280*800.
I would recommend testing with an earlier BIOS version:
https://downloadcenter.intel.com/download/23503/BIOS-Update-MTCDT10N-86A- Download BIOS Update [MTCDT10N.86A]
What does the screen look like when selecting different screen resolution?
Allan.
Were you able to test different BIOS version?
Please let me know your findings.
Allan.
Yes. I lowered the BIOS to version 0165. The result was the same.
Intel engineers! Please add a string 6 resolution 800x1280.
Red marked do not use without consulting Intel. Give me consultation!
Datasheet on a flat-panel: http://www.dragonwake.com/download/exynos4412/HD700-CLAA070WP03XG.pdf http://www.dragonwake.com/download/exynos4412/HD700-CLAA070WP03XG.pdf
I will check with engineering to get information about this. I will post any updates as they become available.
Allan.
