Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
Intel DP35DP black screen, can't boot
LMari7
Hi!
I have a Intel DP35DP (latest bios), intel X3360 and 8GB RAM(4*2GB). Just switched to Q9550S & the error started. Tried out to boot with E6550, no luck!
The PC worked great until several days ago. Now it just boot onto a black screen (with an underline in the top left corner).
I tried to reinstall the BIOS (wtih the ISO image from CD-ROM and the bios jumper out) but it does help as it doesn't boot BIOS at all.
I removed the cmos battery for over an hour, etc.
Also, put the PC Analyser card, which hangs on step EB:
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005500.html Port 80h POST Codes for Intel® Desktop Boards
or "calling legacy option ROM". What does that mean?
Tried to disconnect the CD-ROM, no luck.
What can I do now?
Luka
AlHill
Did you upgrade to bios 484 BEFORE you inserted the Q9550S? If not, put the X3360 back in, upgrade the bios, then insert the Q9550S.
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/DP35DP.pdf https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/DP35DP.pdf
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html Recovery BIOS Update Instructions for Intel® Desktop Boards
Doc
LMari7
BIOS was the latest one, 500 & something.
BTW; after putting Q9550S (which did work, just the WIN10 wouldn't load)...then I've restarted & got this black screen with white underline that's permanently on (not blinking).
Tried to put X3360 & E6550 on motherboard, same thing.
Now removed the jumper to write the BIOS again...it stalled on step 29, according to PC Analyser. :/
What next?
LMari7
Correction, stalled on same step EB...black screen with white underline is ON.
Processor is E6550 inside.
LMari7
