Hi!
I have a Intel DP35DP (latest bios), intel E5300 and 4GB RAM(2*2GB);
The pc worked well until several days ago. Now it just boot onto a black screen (with an underline in the top left corner).
I tried to reinstall the bis (wtih the .bio file and the bios jumper out) but it does nothing.
I removed the cmos battery for over an hour, etc.
What can I do now?
Robert.
Hi thereau,
I am sorry you are having this problem but let me help you.
There are some troubleshooting steps I would like you to see as per your problem description:
http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm?wapkw=no+boot http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm?wapkw=no+boot
Here you can check more information:
http://www.intel.com/support/motherboards/desktop/sb/CS-034312.htm?wapkw=no+boot http://www.intel.com/support/motherboards/desktop/sb/CS-034312.htm?wapkw=no+boot
Kevin M
As I said. I try to recover the BIOS using the .bio file but id does not start the recovery process.
Besides those steps, you can try a different monitor and cables but if the troubleshooting steps from the links above don't fix the issue, I would recommend you contacting your local support:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin M
