Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Intel DP55KG 0_ error on boot after GPU replace
CVere
Recently i have bought a new Graphics Card a Gigabyte GV-R939G1 GAMING-8GD, after the hardware installation I've boot the computer and the boot stuck in the BIOS. When i disable UEFI and change it to Legacy, i have a black screen after the post with a '0_' in the right bottom of the screen. I have removed all of the old graphicscard drivers with DDU and installed the new drivers. Tried to change the VCCS between 1.1 - 1.3.
Still have a '0_' error in the right bottom of the screen.
MOBO: Intel DP55KG (BIOS Version: KGIBX10J.86A.5936.2011.0630.2250, 30-6-2011)
CPU: Intel Core i7 870
HDD1: 128GB SSD (OS installed on this SSD.
HDD2&3: Both 1TB in RAID0.
RAM: 2x 8GB Kingston HyperX Beast DDR3-1600
PSU: TN7RX003 Aerocool AE-750 (750 Watt)
Old Graphics Card: Asus EAH6850
OS: Windows 10
CVere
AlHill
Classic problem: Old motherboard, new graphics card.
Yes, the graphics card will claim backward compatibility, but in recent times this has been a hit or miss issue, mostly miss.
There is no way your board, manufactured more than seven years ago, could predict the future of graphics cards. There is no bios update that will help.
However, you should be dealing with Gigabyte, as they have the ability to modify their firmware to correct problems, if they really want to be backward compatible.
Solution, other than Gigabyte correcting their firmware, is to get a new motherboard, or a graphics card that really is compatible with your board.
Also, it makes little sense (to me) to have a seven year old board and a nice shiny new graphics card that has to operate in a degraded mode (PCIe 2.0). I would want a board that supports PCIe 3.0, so the new graphics card could perform at its best.
By the way, your processor is not supported on Windows 10;.
Doc
n_scott_pearson
Super User Retired Employee
Unfortunately, these are the symptoms of a compatibility problem. These new graphics cards make expectations of the hardware and software/firmware that boards this old cannot meet. One requirement, for example, is support for PCIe 3.0 (your board only supports PCIe 2.0).
CVere
AlHill
I am glad you have the graphics card working.
Doc
Community Manager
Al Hill, N. Scott Pearson, thanks for the assistance.
To: WaterPump
Hello WaterPump,
I am glad to know that you were able to solve your concern.
For further questions do not hesitate to visit our /community/tech Intel® Support Communities.
I am looking forward to hearing from you.
Angie
