Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Intel DP55KG doesn't start ...
Community Manager
I have Intel DP55KG motherboard and Intel core i7 860 processor, after installation motherboard displays 21 > 26 > 31 post codes and restarts. Other components installed:
Cooler Zalman 9900 NT
MSI GeForce GTX460 Cyclone 1024 МБ 256 бит PCI-E
4096Mb DDRIII PC-10666, (1333Mhz) (2x2048Mb) Kingston CL9 (KVR1333D3N9K2/4G)
OCZ DDR3 PC3-10666 / 1333MHz / Platinum Edition / Low Voltage / 4GB / Dual Channel
3x Western Digital Caviar Blue 320GB 7200rpm 16MB WD3200AAKX 3.5 SATA II
Thermaltake ToughPower 600W
In product specification 21 post code says - Initializing a chipset component
26 - Optimizing memory settings
31 - ?
Can someone help with this problem, really don't know what to do to make my computer work ...
John
Community Manager
Just redownloaded pdf with specification to say that post code 31 - Crisis Recovery has initiated by software (corrupt flash)
What I can do with this problem?..
JPisz
New Contributor II
Do you get any video?
There were some earlier reports of certain BIOS/NVIDIA card imcompatibilities.
Do you have an ATI card or other PCI video card you could use to test?
Justin.
Community Manager
2Justin:
You will laugh, but I found the problem... It was jumper which not connected as it should. I think metal connectors inside it has a bit defect, thats why motherboard can't boot. Jumper was swaped 3-5 times and woalla - motherboard booted.
Any way, thx for answer. Didn't sleep 2 days =)
John
Community Manager
I have had this board for a while, kinda finicky, but decided to build a new machine on it. Kept running in to this problem. Thank you for the thread. Replaced jumper, boots right up.
