Intel® Desktop Boards
Peer-to-peer support only
11429 Discussions
Intel DQ45CB capacitor
DMitc5
If you have an Intel DQ45CB motherboard and would be willing to help could you give me the Capacitor information / part # for the one located in position ec62 on the circuitboard. The one identified by the black arrow in the posted image. Thanks a bunch. Intel support said they did not have this info...........
Allan_J_Intel1
I understand you need information about motherboard capacitor.
At this stage, this information is not available through this channel of support. You may address this matter through an Intel authorized distributor and check with a field application engineer as the Intel technical department does not handle part numbers for internal motherboard components.
See here to locate an Intel authorized distributor:
https://www-ssl.intel.com/p/en_US/techprovider/contentns?docid=493983 https://www-ssl.intel.com/p/en_US/techprovider/contentns?docid=493983
Allan.
