Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Intel DQ57TM RAM downclocking
FDeSt
Un cliente mi ha portato il suo PC che dopo aver resettato la CMOS ha cominciato a manifestare un problema, ovvero riavvio continuo in LOOP.
Poi mi sono accorto che aveva 3 banchi di RAM DDR3, dicui uno da 1333MHZ e 2 da 1600MHz e ho letto che questa scheda madre supporto RAM da 1066 e 1333MHz, ma su alcuni forum si parla della possibilità di poter effettuare un downclocking a 1333MHz ma non trovo nulla sul BIOS a riguardo.
Avete link che spiegano come fare su questa mainboard?
Grazie
n_scott_pearson
Super User Retired Employee
It is best to have matching DIMMs across the board. When you mix speeds, the speed of the slowest DIMM will be used. It is also problematic having 3 DIMMs. This prevents the interleaving of memory accesses across the twop memory channels. You should have 2 or 4.DIMMs. If you must have 3 DIMMs, the two matching 1600 DIMMs should go in one channel and the 1333 DIMM should go into the other channel.
This page: DQ57TM Product Documentation & Manuals details the documents that are available related to this board. The Technical Product Specification (TPS) will provide the details you require (such as they are).
