Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Intel DQ67EP and i5-2500T compatibility.
MJack15
Hi
I'm looking to get this board - intel DQ67EP mini ITX but would like to know if it's compatible with the i5-2500T CPU. I've looked at this list but every other CPU is listed except the i5-2500T http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=dq67ep
Jacko
AlHill
If it is not on the list, it is not compatible.
Doc
n_scott_pearson
Super User Retired Employee
(and it most certainly isn't the only Sandy Bridge desktop processor that is not supported; there are actually quite a few)
MJack15
Surprising that an intel board doesn't support an intel CPU. Could be that it's untested.
AlHill
Not surprising to me. It could be untested. But, if you try it and damage your board, you have been warned.
Doc
MJack15
No, not going to get this board.
n_scott_pearson
You do realize that this board was manufactured 8 years ago and Windows 10 is not supported on it, right? This should be yet another strike against purchasing one at this juncture. Of course, you are trying to match it with a 2nd generation Intel Core processor which is also not supported on Windows 10 either.
