Hello.
Hoping someone here can help me.
Ive just built myself a computer.
Spec is:
Intel DQ67EP Motherboard
Intel i5-2500 CPU
Mushkin 8 GB DDR3 12800 Ram
OCZ Vertex Plus R2 SSD
Standard ATX PSU
Im wanting to run with 2 monitors (Samsung and Relisys TFTs)
My issue is that both monitors work in the DVI-I port but when I use either monitor in the DVI-D port all I get is a green fuzzy screen,
This happens from when the machine is turned on.
Windows sees the monitor and extends the desktop to it and ive tried changing settings etc with no joy.
I have tried different monitors in the port, new PSU, updating the BIOS.
Cant see it being a driver issue.
Miby motherboard of the integrated graphics chip in the i5
Picture attached
Any help is much appreciated.
Alan
Hello, Suppler sent me a replacement motherboard and the problem is now cured, thanks for all your help. Alan
Hi alanjob,
I am sorry you are having problems with your system but let me help you.
Based on your description, there are some steps I want you to try:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377
Besides this, you can run the Intel® Processor Diagnostic Tool. This will diagnose the processor and do a stress test to test every single internal component of the processor and in case there is a problem, the result will be displayed. You can download it here:
32 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791
64 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792
Hello
I have tried replacing the cable/monitor and reinstalled drivers.
This happens before the driver even loads.
I have run the Diagnostic Tool and everything passed ok.
I have however sourced a cpu so ill update when I get to try it.
Alan
Hello
Installed the new CPU, same issue so must be a problem with the motherboard.
Does anyone else run this board and have dual displays using the dvi ports?
Alan
We can discard the processor for now but have you tired a BIOS update?
Here is the latest:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22122 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22122
Hi, yes bios update was done. Alan
You are welcome. I am happy to hear your problem is solved.
