I have already set the boot sequence of USB drive as the 1st to boot + enable boot from USB + enable boot from removable devices + enable boot from USB first + disable fastboot.
Set to UEFI mode: USB automatically boot as the 1st
Set to legacy mode: Not bootable unless manually choosing to boot from USB (not practical when I remote to wake-on-LAN)
This case is that I HAVE TO use legacy mode in order to make sure USB to boot into Synology system successfully (UEFI is automatically USB bootable, but with problem loading into Synology system)
I have tried various BIOS setting combinations of settings is BIOS, but still not working.
Environment:
BIOS ver.: SWQ6710H.86A.0070.2018 (Updated to the latest version)
CPU: i5-2500s Memory: DDR3 x 2
Boot USB drive includes: Xpenology 1.03b bootloader
Any help would be very appreciated. Thanks in advance!
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
W10 2004, W10 May 2020, W10 20H1, W10 19041 - A rose, by any other name, still smells.
