Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Intel DX48BT2 with Crucial CT2KIT25664BA1067 memory
ALupi1
Has anyone tried to run an Intel DX48BT2 motherboard with two pairs of Crucial CT2KIT25664BA1067 memory?
I have been running this board with one set (2G x 2) for years and it runs flawlessly, however, not long ago I attempted to add a second pair to bring the board to its 8GB max and the system would not boot. I replaced the existing set with the new one (just to see if the memory sticks were defective), and the board started without a problem, as long as I had only one pair of sticks installed.
Thanks for any help.
Arsene
Silvia_L_Intel1
Hello Arsene, I am afraid to say that this motherboard has been out of support since December, 2010 http://www.intel.com/support/motherboards/desktop/sb/CS-032022.htm http://www.intel.com/support/motherboards/desktop/sb/CS-032022.htm
Some information I can provide you, is that it looks like the actual frequency or latency of the memory is causing conflicts, so I would recommend you to contact the memory manufacture and ask them if these 2 kits can be use to run a dual channel. As you can see, you are able to use them separately, that means they are compatible.
http://www.intel.com/support/motherboards/desktop/dx48bt2/sb/CS-028495.htm Intel� Desktop Board DX48BT2 — System memory
Also check if your board is running the latest BIOS version available.
ALupi1
Thanks, Sylvia, I will contact Crucial and see if they can help. I do have the latest BIOS.
ZAgha
New Contributor II
On what voltages are your RAMs operating? Any OCing?
Are you sure the new sticks are of the exact same model like the old ones? Cause your RAMs have been out of circulation for quite sometime now.
Can you test two sticks of 4GB using only your blue DIMM slots?
I read on Xbit labs that Intel advices not to populate all your DIMM slots. Moreover, if you managed to get a working pair of 4GB per stick you will have better performance.
keep us informed
ALupi1
I believe the voltage is 1.54 volts, there is absolutely no overclocking.
I do not believe I should run the two stick on the blue sockets, as each memory channel has one blue and one white socket. Is this right?
ZAgha
New Contributor II
To operate in Dual Channel with one pair you should always populate the Blue DIMM slots.
I reviewed your board's manual, there are blue & black DIMM slots. As per Intel's manual for your board:
"Remove the video card in the Primary PCI Express x16 connector before installing or upgrading memory to avoid interference with the memory retention mechanism."
Also check this out:
http://www.intel.com/support/motherboards/desktop/sb/CS-011965.htm Desktop Boards — Single and multi-channel memory modes
Are those your RAMs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148150 Crucial 4GB &# 40;2 x 2GB&# 41; 240-Pin DDR3 SDRAM DDR3 1066 &# 40;PC3 8500&# 41; Dual Channel Kit Desktop Memory Model CT2KIT25664BA1067 - Newegg.com
ALupi1
Ziad,
My two existing memory sticks each read as follows: CT25664BA1067.16FSD, so I do believe the link you provided to NewEgg shows the same memory.
As I have stated before, I am trying to find out if there is a way I can make four of these sticks work in my existing motherboard so I can bring the total RAM to the maximum of 8 GB, perhaps by adjusting some BIOS parameter.
To bring the board to the full 8 GBs, I see no other way but to populate all 4 sockets, the two blue sockets, and the two black sockets, but I had a negative experience a while back trying to do this, as I explained in my first message, and I am trying to find out the reason for this.
