Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel DX58SO -- 3 Beeps?
My setup is:
Power Supply Echo Star- output 450 watts
Intel Core i7 920 Processor
Intel DX58SO Socket LGA 1366
Core i7 Dominator 6GB DDR3 RAM
1 TB Hard Drive Hitachi
DVD RW-ROM Lite On
GE Force 512 MB Video Card
My problem is the monitor isn't working at all and I get the three beeps. I have re-installed the memory (RAM) twice and I still get the three beeps. Any ideas?
Highlighted
Community Manager
Re: Intel DX58SO -- 3 Beeps?
Highlighted
Honored Contributor I
Try putting one Ram mod. in channel a dimm 1 by it self you may have a bad connection in channel dimm O , I had a simalar prob and I did this the board would POST but it just told me I had a bad conn. in that Ram slot I still had to RMA the board , But at least it helped me narrow down the problem .
Highlighted
Community Manager
I did that two times before, no change. I bought the new RAM one day ago, we'll see. Thanks for the help, appreciate it.
Highlighted
This may (or may not ) help. Most of the stuff to look at is the dialog between Igor and me. I had a single, out of alignment pin, in the cpu socket that fouled me up. Good Luck.
/message/74912# 74912 http://communities.intel.com/message/74912# 74912
Highlighted
Community Manager
I'm stumped. I bought new Kingston RAM yesterday, no change. I'm guessing I need to go a computer store.
Highlighted
Community Manager
did you clear the cmos after installing the new ones?
Highlighted
Community Manager
I found the problem with the RAM. I'm set on the RAM.
Where is the CMOS on the BIOS? I need help setting it up. I switched the RAID into my BIOS.
Thanks alot.
Highlighted
New Contributor II
Please dun get Kingston in future.
Recommend to use Crucial
