Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Intel DX58SO2 No POST - Blank Screen
Community Manager
I am a newbie so this could be something really simple. I purchased this board to replace another mobo that had a bad USB chipset. All components (HD, video card, CPU, DVD ROM. PSU) were all working fine on other motherboard - just USB chipset was shot.
After installing the new board and powering up the PC, I do not get any display. The monitor doesn't seem to receive any signal. The 80h POST code displayed is 14 (according to the manual that is LAN init).
Here is what I've tried so far:
-checked the CPU for bent pins
-reapplied thermal grease
-replaced all mobo screws and case studs
-tried the PCI-e video card in each of the slots
-pulled all the RAM out and tried to boot (no error beeps...this really concerns me because I was under the impression that I should get some beeps)
-swapped HD SATA cable to other SATA ports
-removed and reseated the CPU and motherboard
-disconnected and reconnected all power cables
-rechecked all cables are connected to the mobo correctly
Can someone please offer some assistance?
Thank You!
Community Manager
Just replaced the CMOS battery. Now the POST code is no longer "14." The POST code is now displaying "00." Still not booting or producing any error beeps.
Also tried removing the video card completely. Still nothing.
Community Manager
OK. Now the POST code is still displaying "00" but I have tried the following with no changes:
-swapped out the PSU (from 700w to 850w)
-installed a brand new PCI-E 2.0 graphics card
Still no display. Anyone have any ideas? I really feel like the CPU isn't the issue.
Community Manager
You could try powering up without memory, if you get three beep tones, the processor and the board are communicating each other.
Take a look at this link for more troubleshooting:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005660.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005660.html
Allan.
Allan_J_Intel1
I was checking this post for more information. Did you get 3 beep tone codes without memory?
Allan.
Community Manager
Sorry. I tried everything. Removing everything and just powering up the mobo alone didn't even produce any beeps. I've already returned the mobo to the dealer and purchased a Gigabyte mobo. Installed the Gigabyte board with all the same components and everything fired up perfectly. Bad board I guess. But a search for this issue in any search engine shows a massive amount of users with the same issues. So...I will not be buying any more Intel boards any time very soon.
BTW, for some reason Intel would not let me log back in with my original username...maybe I made someone mad. :-/
Community Manager
It's sad to hear you did not get the computer work again. Thank you for your feedback. I hope you enjoy the new computer.
Allan.
